dodsworth_gti 11 Posted August 6, 2007 hi in need of a bit of help,i find 205 gti washer jets to be a bit,crap lol been looking into getting so tubing and relocating the jets onto the wipers,but i cant find the jets that go on them any where??? of is it blades that you buy with them mounted on?? many thanks ben Share this post Link to post Share on other sites
welshpug 1,666 Posted August 6, 2007 you can use 405 spray bars, I used the spare ones I had after replacing the wipers on my Mi16 and getting new spraybars with them. Share this post Link to post Share on other sites
dodsworth_gti 11 Posted August 6, 2007 cheers buddy Share this post Link to post Share on other sites
Super Josh 4 Posted August 6, 2007 I use the ones from a 2002 onwards Saxo, I think. The really spray lots of water onto the screen and you don't end up with redundant ones on the bonnet Josh Share this post Link to post Share on other sites
hengti 2 Posted August 6, 2007 if you're getting blocked nozzles (rather than just poor performance), it's worth hosing out the screen wash reservoir (if you haven't already) as they silt up with muck Share this post Link to post Share on other sites
sutol 0 Posted August 6, 2007 You may find what you are looking for in a yard that scraps trucks. I once stole a pair of jets of the wiper arms of a Volvo truck. I'm not suggesting you do it, far from it, it's very naughty but they clipped on to the wiper arm and sprayed four jets of water each on to the screen. Brilliant Share this post Link to post Share on other sites
Ahl 4 Posted August 6, 2007 You may find what you are looking for in a yard that scraps trucks. I once stole a pair of jets of the wiper arms of a Volvo truck.I'm not suggesting you do it, far from it, it's very naughty but they clipped on to the wiper arm and sprayed four jets of water each on to the screen. Brilliant That sounds similar to the 405 ones. Share this post Link to post Share on other sites
GLPoomobile 958 Posted August 6, 2007 you can use 405 spray bars, I used the spare ones I had after replacing the wipers on my Mi16 and getting new spraybars with them. Where did you buy them from? Do they fit normal 205 arms or do you need 405 arms? Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted August 6, 2007 (edited) Where did you buy them from? Do they fit normal 205 arms or do you need 405 arms? they just clip to the blade themselves. im not sure if you can buy the spraybars seperate. i have always had them new on new blades. renault master vans have the washer jets on the wiper blade as well. its a small pod about 5 inchs long. looks very neat. Edited August 6, 2007 by pugger Share this post Link to post Share on other sites
welshpug 1,666 Posted August 6, 2007 like pugger said, I'm not sure if they're available separate (a search of pug's parts files will soon tell though...), but they simply clip to the blade's frame. Iveco Daily's use similar clips to the master too. Share this post Link to post Share on other sites
dodsworth_gti 11 Posted August 7, 2007 405 ones are looking winners at the mo,but now you mention it,our merc sprinter work van has some,and im thinking i might nick them nah,second hand merc van specialist down the road and were freindly with him so might look at ours tomorrow and then go down and see what he has i could pinch alos think about new wash bottle to Share this post Link to post Share on other sites
jackherer 543 Posted August 7, 2007 Citroen Xantia rear wipers have tiny spray bars completely hidden under the wiper arm. Share this post Link to post Share on other sites
Baz 421 Posted August 7, 2007 307 washer jets are a little bigger, but they emit a really good fanned jet of water across the screen, also doesn't leave useless holes or old jets in the bonnet. I run a BX setup on my white 205 on a single wiper, has a tube clipped to the arm with holes in it that squirt the water as the arm moves, similar to the 405 ones, works pretty well. Another tip is to extend the feed to the jets and wrap it round a coolant hose for heated washers!! Share this post Link to post Share on other sites
pete1986 2 Posted August 7, 2007 I find that the rear washer jet has far from poor performance - it clears the rear window and lands on the roof! spray bars at the front sound like a good idea might give it a try Share this post Link to post Share on other sites
Veero 1 Posted August 8, 2007 I find that the rear washer jet has far from poor performance - it clears the rear window and lands on the roof! Ha! You got nothing on me, my rear one clears the roof and if Im stopped in traffic and the wind's right I can get the car in front I got a new pair of 309 twin jets from pug and they're s*it, I cleaned out the washer tank too and they still gum of with crap and a re a pain in the arse to align properly. I carry a pin around in the ashtray and it seems every 4th journey have to realign them slightly. Aim slightly too high and they clear the roof, too low and they just foam up and make puddles on the bonnet and there only seems to be a fraciton of a degree of difference... Damn things. The 307 ones sound good, I like the pattern the ex's Polo makes on the screen, a fine spray which covers the whole screen, not just 2 pathetic water pistol dribbles... Share this post Link to post Share on other sites
saveloy 8 Posted August 8, 2007 I have wrapped the washer tube around 2 coolant pipes and then onto a second pump, before connecting them to the standard jets. The result is, plenty more pressure and warm water. Share this post Link to post Share on other sites
GLPoomobile 958 Posted August 8, 2007 I have wrapped the washer tube around 2 coolant pipes and then onto a second pump, before connecting them to the standard jets. The result is, plenty more pressure and warm water. I was planning on doing this too. I'm moving my reservoir to the drivers side, so the top radiator hose is ideal to spiral the washer hose around on it's way up to the jets. But what pump did you use as your secondary pump? It obviously needs to have a hose fitting on the inlet and outlet sides, but I can't remember if the original pumps have them on the inlet side or if it's just a large opening Share this post Link to post Share on other sites
Guest firenzaman Posted August 8, 2007 I was planning on doing this too. I'm moving my reservoir to the drivers side, so the top radiator hose is ideal to spiral the washer hose around on it's way up to the jets. But what pump did you use as your secondary pump? It obviously needs to have a hose fitting on the inlet and outlet sides, but I can't remember if the original pumps have them on the inlet side or if it's just a large opening Theres a kit on ebay where you get good quality replacement wiper blade witha 3 point jet spray attached and all the required tubing for around £5 per wiper. They are good as I have them fitted to my 205 gti. Share this post Link to post Share on other sites
dodsworth_gti 11 Posted August 8, 2007 any one know if i will get these at my local motorfactors??the 405 ones i mean Share this post Link to post Share on other sites
welshpug 1,666 Posted August 8, 2007 GSF for certain, not sure of anywhere else Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted August 8, 2007 I use a 406 washer bottle pump and it is turbocharged compared to the 205 one! I also use the 306 twin jets on mine and they work fine once they are aligned. I hear you can get some nice chrome ones, maybe even some with handy blue LEDs in Share this post Link to post Share on other sites
Peetypug 5 Posted August 8, 2007 i took mine off a jcb at work they have 2 spray points either side (4 per blade) and are located with a screw just run some rubber hose to them under the grill below the screen and get the fittings from a 405 to connect to them now that i've writen it you might as well get the lot from a 405 at the scrappy just run it under the grill and make holes to suit Share this post Link to post Share on other sites
saveloy 8 Posted August 9, 2007 Everything I needed I bought from Halfords. I also fitted an in line one way valve, so as to keep the pressure at the nozzles. It has worked very well for the past few years. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted August 14, 2007 I use a 406 washer bottle pump and it is turbocharged compared to the 205 one! I also use the 306 twin jets on mine and they work fine once they are aligned. is that a straight swap for the 205 one? I hear you can get some nice chrome ones, maybe even some with handy blue LEDs in on no, don't mention those ever again please! ;) Share this post Link to post Share on other sites
