hi3afp 0 Posted August 6, 2007 (edited) HI After closing the roof of mi 1.6 cti, the horn the C. lighter and the roof itself fails. The fuse is ok, and each component work when connect separately. The earth its ok, but the positive terminal have no voltage read on the components. I search the forum but i dint find the location of the relay for the horn or the roof. The fusebox of the 205 fails sometimes ? Regards Ariel Edited August 6, 2007 by hi3afp Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted August 6, 2007 The hood relays are in the boot on the left hand side I believe. I am not aware of these failing regularly. Share this post Link to post Share on other sites
hi3afp 0 Posted August 28, 2007 The hood relays are in the boot on the left hand side I believe. I am not aware of these failing regularly. Hi Problem solved, the problem was the fusebox i change it, and all work again Share this post Link to post Share on other sites
