wildejon
Solar Powered Battery Trickle Charger
mogsman
I have one. Its not great with the cigar socket, better to cut it off and stick on some crocodile clips to connect to the battery. Maplins usually sell these for a tenner.
Ian
wildejon
Attaching it that way would be fine. Do you find that it does what it says on the tin?
Thank
GLPoomobile
I posted a topic on this about 6 months ago as my car is kept on the street and not used often. The resounding forum answer was that they are crap and a waste of time. I didn't believe that :) but didn't want to waste my money so never bought one.
Would be interesting to hear if anyone has used one to good effect (Mogsman?)
Ryan
A 1-Watt charger wouldn't even replace the power drained by an alarm (if you have one). 10W would be a batter starting point, and 15 or 20W better in the long term - not so cheap though.
wildejon
That is a fair point!
Shame, I was after something like this so I could keep it topped up without removing the battery and bringing it home (its in a garage a couple of miles away...)
richard
i have one.....
dont bother.
you'll need a 5w minimum really, assuming you dont have a radio/or cat1 alarm.
You might just get away with a 5w if you have a cat2 and nothing else. otherwise its 10w.
my ones going onto the shed to power a lead acid battery for a light. About all its good for really.
mogsman
Mines used for my bike which does keep the volts up, might not be up to the task for a car battery though.
It does produce around 14 volts with the cable shortened to a minimum.
Ian
