AdamP 0 Posted August 2, 2007 Has anyone run 185/60 R14s on a non-GTi 205? If so, what offset wheels were you using and did you get much/any scrubbing. Got a set of Yoko A021Rs on my Locost that I want to stick on my 205 but obviously don't want to damage the car or tyres! Share this post Link to post Share on other sites
welshpug 1,675 Posted August 2, 2007 should be fine, I've seen many an XS with 1.6 gti speedlines. Share this post Link to post Share on other sites
Sandy 191 Posted August 3, 2007 ^^^^ 24mm offset. They might rub, the shells vary and some do, some don't. My old Rallye rubbed with them against the lip inside the arch by the bumper bracket and the arch lip itself. Share this post Link to post Share on other sites
DaveK 0 Posted August 3, 2007 my old 1.1 205 had 106 gti wheels and it rubbed on the inside aswell, just thinner arches Share this post Link to post Share on other sites
Casanova 0 Posted August 6, 2007 (edited) 2 of my XSs have those tyres, and they both rub a little. The fronts rub on full lock, and the rears under heavy load (but only on the plastic bumper which can be ground back if you wish). Just thought though, what's the offset on those Jupiters? If its less than the 1.6 alloys (ET25) then that would explain the rubbing Might have to reshape the inner arch? § Edited August 6, 2007 by Casanova Share this post Link to post Share on other sites
AdamP 0 Posted August 6, 2007 The Jupiters are ET19, so stick out 6mm more. I think it can be sorted with a bit of rear bumper fiddling. Adam Share this post Link to post Share on other sites
