vern 0 Posted August 1, 2007 On my Diesel "Thunder bus" one of the front brakes is sticking, what do i do to fix, strip and replace seals etc, or do I just get a recon one? Share this post Link to post Share on other sites
Stonesie 0 Posted August 1, 2007 It depends whats up with it, have you had the wheel off and had a look yet? It could just be a stuck pad in it's carrier, next thing to check is the caliper sliders themselves, i think you can buy recon kits for these and sort them out easely enough. The least likely thing is if its the piston itself thats jammed, i would buy a recon caliper if it's that, once the piston is rusty it pitts the surface and it might not re-seal 100% eaven with new seals. Share this post Link to post Share on other sites
vern 0 Posted August 1, 2007 thanks for reply. Not had wheel off yet, just hoping to get a plan together before I start. Share this post Link to post Share on other sites
