Guest moo Posted July 30, 2007 (edited) hi there. have a 1.9 205. the drivers side at the back sits bit lower then the other. i am pritty sure its cuz the bearing in the cross member is gone. seems to have excesive play. is this likely to cause it to sit lower? and what is the best way foward? reconditioning the beam thats on. but how likely is it that the shaft or crosmember is damaged? also should i get a new beam to recon? can i use any beam like the 1.6 etc. or do the trailing arms have different mounting points for the calipers? and does any one know of a place i can buy a reconed beam? thanx for reading. bit of a long one. Edited July 30, 2007 by moo Share this post Link to post Share on other sites
