Guest firenzaman Posted July 29, 2007 Does anyone know how to tell the difference between 205 gti and 309 gti lower front wishbones. Is there a code on them or is it just a matter of measuring. Could you fit a 309 to a 205 by mistake and if so what would be difference be if any when fitting it. Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted July 29, 2007 firenzaman said: Does anyone know how to tell the difference between 205 gti and 309 gti lower front wishbones. Is there a code on them or is it just a matter of measuring. Could you fit a 309 to a 205 by mistake and if so what would be difference be if any when fitting it. from memory im sure theres about a 15mm difference in length, if you did fit a 309 one the driveshaft would probably pop out of the hub. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 30, 2007 The 205 ones all seem to be ribbed the 309 one's are plain Share this post Link to post Share on other sites
Sandy 191 Posted July 30, 2007 Originally 309 ones were ribbed and some pattern ones are. Peugeot no longer supply ribbed replacements though, in fact the last set I ordered looked so like the pattern ones I've got, I refused them (at £185 a side, don't take the pi££!) Share this post Link to post Share on other sites
brianthemagical 1 Posted July 30, 2007 you'll always be trying to straighten the wheel everytime you go to a different side of the car, it is quite noticable. Share this post Link to post Share on other sites
205mattgti 0 Posted August 4, 2007 309 lower wishbones will give u a greater neg camber than that 205 ones Share this post Link to post Share on other sites
welshpug 1,675 Posted August 4, 2007 brianthemagical said: you'll always be trying to straighten the wheel everytime you go to a different side of the car, it is quite noticable. you mean you havent had the tracking adjusted to suit? Share this post Link to post Share on other sites
