gti-si 0 Posted July 29, 2007 (edited) I've got a Group N exhaust on at the moment. As i'm driving to prague in september, want to make the car a little quieter. Will this do the trick? Or will I need a full system? http://cgi.ebay.co.uk/Rear-Silencer-Peugeo...1QQcmdZViewItem Edited July 29, 2007 by gti-si Share this post Link to post Share on other sites
Alastairh 47 Posted July 29, 2007 Not really. The Group n is straight through with no mid section, and thats just a back box. best bet, just put a wanted add up. Alastair Share this post Link to post Share on other sites
GLPoomobile 958 Posted July 29, 2007 That box has an olive fit joint, so won't fit the Group N mid section as it's a sleeve fit. Unless of course you are going to get a standard mid section, in which case get one with an olive joint and you are sorted. You'll probably need to get a new center section anyway as just fitting a standard back box probably won't quieten it down enough. Let me know if you are getting rid of the mid pipe as mine has a massive hole in it! Share this post Link to post Share on other sites
Ryan 99 Posted July 29, 2007 If it's a genuine pug group-N then it won't fit as the joint between the backbox and centre pipe is different. Share this post Link to post Share on other sites
gti-si 0 Posted July 29, 2007 That box has an olive fit joint, so won't fit the Group N mid section as it's a sleeve fit. Unless of course you are going to get a standard mid section, in which case get one with an olive joint and you are sorted. You'll probably need to get a new center section anyway as just fitting a standard back box probably won't quieten it down enough. Let me know if you are getting rid of the mid pipe as mine has a massive hole in it! I'll tell you what steve, find me what I need to quieten it down, be it a full system or whatever will work ...and i'll send you down the mid section or you can collect i if your up to Edinborough recently... Deal? haha Share this post Link to post Share on other sites
