monty69 6 Posted July 29, 2007 Has any one fitted one of these whiteline jobbies yet? It looks like it mounts to back axle with u bolts?No problems with them wearing into rear beam? Do you think it would fit a 306 beam with same u clamps? Not bothered about extra width as spacers could be used for 306 Share this post Link to post Share on other sites
Nathan 0 Posted July 30, 2007 I ordered one on friday, hope to have it fitted by the end of the week, will report back then. Share this post Link to post Share on other sites
205toby 0 Posted August 24, 2007 Bringing up an old topic BUT.. Noticed no one else seems to have fitted this swaybar? I just got mine on (1 week ago) and besides hitting the exhaust it went on fine! I have it set to soft and the car has been tightened p and seems to have less rear end roll. Most importantly though, it doesn't cock the inside rear wheel around sharp corners anymore! A good buy for the money. Toby Share this post Link to post Share on other sites
Jrod 7 Posted August 24, 2007 I thought with the ARB it would cock the wheel more? Share this post Link to post Share on other sites
VisaGTi16v 1 Posted August 28, 2007 wtf is going on in your avatar Jrod Share this post Link to post Share on other sites
VisaGTi16v 1 Posted August 28, 2007 Very although possibly not the best bit of parking ever! Share this post Link to post Share on other sites
monty69 6 Posted August 29, 2007 Would it fit a 306 beam with minor adjustments? Share this post Link to post Share on other sites
205toby 0 Posted September 6, 2007 Would it fit a 306 beam with minor adjustments? I'd say so, probably just need larger U clamps to fit around the beam. Toby Share this post Link to post Share on other sites
bren_1.3 1 Posted September 6, 2007 whats the real deal with these. everyone showed lots of interest in these when they were being developed and then it seems to have died out? where they not much use in the end? what was the range of adjustment they offered? Share this post Link to post Share on other sites
205toby 0 Posted September 14, 2007 whats the real deal with these. everyone showed lots of interest in these when they were being developed and then it seems to have died out?where they not much use in the end? what was the range of adjustment they offered? Yeah, I was thinking the same thing! Im happy with mine, seems to work well. I had it set on full soft but I've now set it to medium and the car definatley has less understeer and I like being able to "Tune" the oversteer- Really entertaining set on fully stiff! Toby Share this post Link to post Share on other sites
Normski 1 Posted September 14, 2007 205toby-How does it affect the grip in the wet? On the different settings? Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted September 17, 2007 I have one too...works fine and it is worth the money...I made some modification on how it is fitted to the trailing arm though...I welded it. Share this post Link to post Share on other sites
engine killer 6 Posted September 18, 2007 i am using 23mm arb but am interested in the Whiteline adjustable arb too. can anyone tell the difference between each setting of the adj. arb to original and 23mm? is the softest equal to the original? is the hardest same as 23 or 24mm? thanks. Share this post Link to post Share on other sites
205toby 0 Posted October 9, 2007 Still fine in the wet- no noticable oversteer if its driven half sensibly! You can definatley feel a difference between the settings- soft is much stiffer than the standard bar because this works in conjunction with the stock ARB- It's almost like having two! Car handles soooo much better though, took 2 seconds of my lap times without any other mod! So much more drivable and it's simple to flick between understeer, oversteer or wherever you want it! Toby Share this post Link to post Share on other sites
engine killer 6 Posted October 11, 2007 Still fine in the wet- no noticable oversteer if its driven half sensibly! You can definatley feel a difference between the settings- soft is much stiffer than the standard bar because this works in conjunction with the stock ARB- It's almost like having two!Car handles soooo much better though, took 2 seconds of my lap times without any other mod! So much more drivable and it's simple to flick between understeer, oversteer or wherever you want it! Toby Please forgive my stupid question, is Whiteline's ARB designed to use in conjunction with stock ARB? I though it was designed to work alone. Share this post Link to post Share on other sites
bren_1.3 1 Posted October 11, 2007 its used in conjunction with the stock ARB yes. Share this post Link to post Share on other sites
engine killer 6 Posted October 11, 2007 its used in conjunction with the stock ARB yes. thanks It will be great then, under normal circumstances we change ARB we want it stiffer. with it dangling means it is same as before and we can try shifting the connection points to see the difference. May I ask how many holes on each side? Thanks! Share this post Link to post Share on other sites
superhero 0 Posted October 11, 2007 Hi Guys. Can someone tell me, are you getting these from whiteline direct, or has someone organised a group buy? I thought i had seen a group buy a while ago, but for some reason, i can't access that area of the forum today, keep getting blank screens! Thanks. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted October 11, 2007 nope, via their distributor: http://forum.205gtidrivers.com/index.php?showtopic=74070 Share this post Link to post Share on other sites
superhero 0 Posted October 15, 2007 nope, via their distributor: http://forum.205gtidrivers.com/index.php?showtopic=74070 Thanks very much, that's given me all i need to know Share this post Link to post Share on other sites
Nathan 0 Posted October 15, 2007 May I ask how many holes on each side? 3 Share this post Link to post Share on other sites
engine killer 6 Posted October 15, 2007 3 thanks a lot. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted October 15, 2007 btw, what's the thing with all these rolleyes smileys? Share this post Link to post Share on other sites
