large
Dizzy Over Me Dizzy
large
I have just put my 1.9 lump in my 1.6 but i am having to use the 1.6 dizzy, will it work? If not why not :unsure:
Mikey S
it will work but the advance weights will be sprung differently, so the advance igntion timing will be wrong.
large
Sorry i'm not 100% what you mean (it's late and i'm thick) but as long as she will run happy days :unsure:
boombang
http://en.wikipedia.org/wiki/Distributor
have a quick read here as it explains it pretty well.
Notably: "The distributor also houses the centrifugal advance unit: a set of hinged weights attached to the distributor shaft, that cause the breaker points mounting plate to slightly rotate and advance the spark timing with higher engine rpm. In addition, the distributor has a vacuum advance unit that advances the timing even further as a function of the vacuum in the inlet manifold"
Basically weights spin round changing the timing of the ignition - a 1.6 dizzy is made differently to a 1.9 so they will work, just not be optimal for that engine and likely to lose you performance.
large
Thank you very much. :lol:
Guest
