Moz_Goodwood 0 Posted July 28, 2007 Hiya all can some one tell me what the yellow pipe on the right is? and should i connect it to my spare breather out on the carbs manifold on the left? cheers paul Share this post Link to post Share on other sites
welshpug 1,682 Posted July 28, 2007 cant see very clearly on the pic but If it goes to the dizzy from the intake manifold its the vacuum advance pipe, ideally to get a decent signal it needs to be connectoed to all 4 tracts, but 2 will suffice, has to be cylinders 2 and 3 due to the firing order. Share this post Link to post Share on other sites
Moz_Goodwood 0 Posted July 28, 2007 yeah it looks like it goes in under neath the dizzy could i connect them up using 'y' pieces (both breathers) then run it into the dizzy? also the breather on the other side of the carbs ive used for the brakes, if i "share" this will it effect the brakes? Share this post Link to post Share on other sites
