madspikes 41 1 Cars Posted July 28, 2007 I have just aquired a speed sensor from some newer pug, its the 3 pin type with the speedo cable through drive. I know the connections are +ve, ground, and signal out, but I dont know which pins are which and whats the input voltage. Can anyone help me out? Thanks Mad. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 28, 2007 pin 1 live, pin 2 earth, pin 3 signal. Sorry forgot to reply to PM. I might have the wiring connector for it somewhere as well if you need it. Share this post Link to post Share on other sites
madspikes 41 1 Cars Posted July 28, 2007 pin 1 live, pin 2 earth, pin 3 signal. Sorry forgot to reply to PM. I might have the wiring connector for it somewhere as well if you need it. I take it thats left to right, looking at it with the connector closest to you? I already have a connector, the OE throttle switch plug fits nicely! Thanks, Mad. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 28, 2007 not sure which end is which, the plug has the numbers stamped into it, will try and dig it out check for you Share this post Link to post Share on other sites
