DaveK 0 Posted July 25, 2007 The lights on the dash are all working except: Behind the rev counter/speedo etc (did a search and going to change the roller stat thing as i have a spare) The dipped headlight and sidelight dont light either The sidelights work, as do dipped beams and full beams. the dash full beam light works aswell Are these most likely to be just the bulbs since its just the 2? Also am i right in saying that if a guage is working wi will move up off the bump stop slightly? Apologies for the million questions Cheers, Dave Share this post Link to post Share on other sites
hengti 2 Posted July 25, 2007 (edited) does sound as though you've got a few duff bulbs in the instrument cluster. the warning/lighting lamps have individual bulbs but the back lighting for the dials is cast around by numerous bulbs; i.e. it may be that there's only the one backlight bulb that has gone if you're missing light in one particular area of the dials (regardless of whether or not that missing light is affecting more than one dial) not sure if that makes sense.. anyway, whip the instrument cluster out and try swapping the bulbs/holders around for those that still work to be sure it's not a connection problem. you can buy bags of bulbs from Pug - they're v cheap. not sure if you can get the holders though. i'm guessing the gauge needles might move off their stops a little before starting the engine - although the fuel gauge should register before then IIRC ed. sp Edited July 25, 2007 by hengti Share this post Link to post Share on other sites
DaveK 0 Posted July 25, 2007 ive got another set of clocks i can try aswell, cheers! Share this post Link to post Share on other sites
