watford1gti 0 Posted July 24, 2007 hello all, i havent been a member on here or 205gti owner for long and already im posting on here with problems where do i start,first of all its a 1.6gti with a k&n and exhaust now the problem i took the car out for a drive, she was no more lumpy than usual from cold, then i took ot for a little drive then when i put my foot down there was no power and it sounded like it was running on 2 or 3 cylinders. also it would sort of survive ticking over but when revved the little light on the dash (looks like a radiator/cooling sign) lights time with the lumpyness, i checked the coolent and it needed a bit of a top up. ive got a new dissy cap,rotor arm,plugs,leads and oil and filter to do a service already on order because i was going to do a service anyway, any help would be much appreciated matt Share this post Link to post Share on other sites
Smigzy 0 Posted July 24, 2007 Hi mate, i had the same problem, it started off using a bit of coolant evey week, then after a bit of a fruitful drive, it sounded as though it was running on 3 cylinders. It turned out to be the cylinder head gasket. Is there any oil in the coolant or vice versa? Does the coolant tank smell of fuel? How much of a top up did it need? Does it use coolant often? Best thing to do would probably take it to a garage for a compression test to see if the gasket has gone. Other than that mate, i dont have a clue!! Hope you get it sorted! Share this post Link to post Share on other sites
welshpug 1,666 Posted July 24, 2007 check the injector plugs. Share this post Link to post Share on other sites
luggy 13 Posted July 24, 2007 When starting from cold my 8v used to run on 3 cylinders for the first 20-30 secs. When I recently serviced it I changed the plugs and put copper grease on the threads, problem solved. Share this post Link to post Share on other sites
