large 33 Posted July 23, 2007 I am putting a 1.9 lump in my 1.6 Gti (instead, not as well ) I was just going to swap the block and head but after reading some posts i think i will also have to change some other bits. Air flow meter,injectors,ecu. Do i have to change these bit or can i use the 1.6 ones and is there any other parts i should change? Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 23, 2007 if you are using any 1.6 bits use them all, IE ecu with injectors, dizzy and AFM, or all 1.9. You wont get the full benefit if you run 1.6 parts. Much better to swap them over to 1.9. Share this post Link to post Share on other sites
large 33 Posted July 23, 2007 Spot on, thank you very much. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 23, 2007 http://www.205gtidrivers.com/articles/e1-gti16to19.html Graham. Share this post Link to post Share on other sites
large 33 Posted July 24, 2007 Thanks for that.It has just given me a small problem, the 1.9 engine i have to go in has the coil mounted above the manifold any handy hints. Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 24, 2007 Thanks for that.It has just given me a small problem, the 1.9 engine i have to go in has the coil mounted above the manifold any handy hints. Just take the coil off and pretend it was never there! Use the coil set up you already have 1 Share this post Link to post Share on other sites
large 33 Posted July 25, 2007 will do thanks are the injectors interchangable i.e. dose one plug fit all. Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 25, 2007 will do thanks are the injectors interchangable i.e. dose one plug fit all. Injector plugs fit onto both type of injector (blue 1.6 and yellow 1.9). As they all fire at once the order is not important either Share this post Link to post Share on other sites
zowow 0 Posted July 25, 2007 easily done, even though mine took me three months lol Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 25, 2007 easily done, even though mine took me three months lol My last was a little under 8 hours Share this post Link to post Share on other sites
large 33 Posted July 26, 2007 Steve you dont want to come and do mine,I will give you £10 for your petrol. Share this post Link to post Share on other sites
