DaveK
Removing Body Decals
DaveK
looking at buying a 205 that has been track prepped but it has advertising decals over it
how are they removed? is it easy enough?
Cheers, Dave
28CRAIG
Should be easy enough just use a hot air gun but the paint could be faded if been on for a while.
Hot air gun helps, clean up with panel wipe or similar to remove gluey substances then polish. :blush:
It's pretty easy, some more so than others depending on type of adhesives, and how it was applied, and even down to whether the paint was clean/polished before they were applied.
I do quite a few, doing a Skyline atm, has massive great stickers up it! :P
Edited by BazGTMi
SamGTi
An air gun helps but I have removed decals in the past with my girlfriends hairdryer. All you need to do is melt the glue then polish it off afterwards
Paintguy
Couldn't have put it better myself :)
Experiment with the amount of heat applied as you remove them - too little and the vinyl can be brittle and break off in little pieces. Too much and you'll leave all the glue behind on the panel.
Arahan
Is it Laser green by any chance??
Edited by Arahan
