pee vee 1 Posted July 15, 2007 Hii.. have a rebuilt Mi16 fitted to the car.. it seems to be putting out quite a bit of (what looks like) blue smoke though :S have literally only run it to check it works so far.. questions: 1: checked the oil level. its slightly above max on the dipstick (bout 4-5mm above it) would this cause the engine to smoke?? 2: the cam cover breather pipe isnt connected yet.. and ive done away with it breathing back into the inlet manifold from the top of the oil filler if the breather is disconnected would this cause it to smoke?? bit worried at the mo to be honest.. Share this post Link to post Share on other sites
James_m 0 Posted July 15, 2007 What to the breathers vent to now? are they just sealed? Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 they are just to atmosphere at the mo :S till i connect everything again. Share this post Link to post Share on other sites
James_m 0 Posted July 15, 2007 (edited) Cant see why that would cause it to smoke then, assuming its exhaust smoke. My mate Built an S16 once which smoked for the first couple of hundred miles strangely. I think its quite common. Id just use it and see how it goes. Edited July 15, 2007 by James_m Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 yeah. got a few bits and pieces to sort out yet.. another week and it might be back on the road. then i'll have to keep fingers crossed... everything looked fine with the engine though.. the engineers didnt say anything was worn or owt! Share this post Link to post Share on other sites
DamirGTI 342 Posted July 15, 2007 Hi ! Which oil did you put inside for running-in ? full synthetic , semi synthetic or mineral oil ? This blue smoke can occur when people fill rebuild engine with full synthetic oil (if the piston rings are changed you should not use full synthetic oil for running-in period ...) cheers Damir Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 15, 2007 You should only get some smoke on start up really with all the assembly grease etc burning off, Did you use new Rings? Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 its using mineral oil at the mo ! Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 (edited) Miles.. yes new rings were fitted. spose it could be assembly grease etc... but seems too much for that IMO Edited July 15, 2007 by pee vee Share this post Link to post Share on other sites
DamirGTI 342 Posted July 15, 2007 ...me thinks that it will be fine after few miles of running in if you build it properly i want worry it just need some time to loose an then it must stop smoking Damir Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 (edited) lets hope! lol as said, all needs finishing off.. so maybe another weekend (only time i get really) and it might have a few miles under its belt.. Thanks guys! Edited July 15, 2007 by pee vee Share this post Link to post Share on other sites
boldy205 75 Posted July 15, 2007 more than likely just old oil buring off. should not last long! Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 thinking about it.. does the black coating on them QEP spacer plates burn off and smoke?? cos it only seems to do it about 30 seconds to a minute after its been started..when the manifold gets warm? Share this post Link to post Share on other sites
boombang 2 Posted July 15, 2007 Are you talking about smoke from the engine bay rather than the exhaust? If the rocker cover doesn't seal perfectly, it will leak out the back onto the exhaust manifold and smoke when hot. Typically when you remove it some oil will fall as pools over the exhaust cam - if you've only just put it all together, it might be a case of running it for a while to burn it off. I would also drop out the oil and fill to correct level. Too much oil won't do any good. Share this post Link to post Share on other sites
pee vee 1 Posted July 15, 2007 no its out the exhaust!! i have sorted the oil now. did that as soon as i realised. Share this post Link to post Share on other sites
