james_pug
205 Vts/gti Driveshafts
james_pug
hi
ive got a 205 convertable with a 106 gti/ vts engine in and need a new passenger side driveshaft (short one) what is the driveshaft off though is it just a 1.4 205 one or is it a vts/gti one
spike
Is your gearbox out of a 205 or 106 GTi/Saxo VTS? The 106/Saxo has a stronger diff pin so the driveshaft splines sre shorter on the gearbox side than a standard 205 MA 'box.
If it's a 205 'box you can use a 205 'shaft.If it's a Saxo/106 'box you will have to make up a 'shaft using the inner cv joint off a Saxo/106 and the 'shaft and outer joint off the 205.
Hope this helps!!
Mike Geen
Teamgeenracing.com
