sonofsam 5 Posted July 13, 2007 Hi All, After partially stripping my front end down this afternoon (replacing top mount studs for m8's and fitting pug wishbone bushes) Discovered I had two split boots on the wishbone ball joints and one joint was very dry and needs a new wishbone anyway. So I went on the hunt for boots, as one 'bone joint was still stiff and not let go of all it's grease yet,(still worth replacing the boot I thought). Found these: Item number: 130134144583.size looks about right Im off to the motor factors tommorow to see what they can supply, and get a new wishbone. Anyway, I maybe able to get part numbers etc. Thought this may prove usefull for future searches! Cheers Sam Share this post Link to post Share on other sites
Rippthrough 98 Posted July 14, 2007 Hi All,After partially stripping my front end down this afternoon (replacing top mount studs for m8's and fitting pug wishbone bushes) Discovered I had two split boots on the wishbone ball joints and one joint was very dry and needs a new wishbone anyway. So I went on the hunt for boots, as one 'bone joint was still stiff and not let go of all it's grease yet,(still worth replacing the boot I thought). Found these: Item number: 130134144583.size looks about right Im off to the motor factors tommorow to see what they can supply, and get a new wishbone. Anyway, I maybe able to get part numbers etc. Thought this may prove usefull for future searches! Cheers Sam Share this post Link to post Share on other sites
