sonofsam
Wishbone Ball Joint Boot
sonofsam
Hi All,
After partially stripping my front end down this afternoon (replacing top mount studs for m8's and fitting
pug wishbone bushes)
Discovered I had two split boots on the wishbone ball joints ;) and one joint was very dry
and needs a new wishbone anyway.
So I went on the hunt for boots, as one 'bone joint was still stiff and not let go of
all it's grease yet,(still worth replacing the boot I thought). Found these: Item number: 130134144583.size looks about right :D
Im off to the motor factors tommorow to see what they can supply, and get
a new wishbone.
Anyway, I maybe able to get part numbers etc. Thought this may prove usefull for future searches!
Sam
Rippthrough
Hi All,
Discovered I had two split boots on the wishbone ball joints :D and one joint was very dry
a new wishbone.
Sam
