brianthemagical
Gti-6 Sump On To Xu9ja
brianthemagical
as above, i'm looking at getting a gti 6 sump for my 1.9 8v. will it just go straight on? if it does, do i need the 1.9 spacer plate and which dipstick do i use for accurate readings? the oil pump is standard. thanks.
Sump fit's on without any problems at all, Just make sure you get the bolt's too, No sump stiffener needed as the GTi6 sump's are full depth, Std dipstick too
brianthemagical
thanks very much for the reply. i take it the bolts are shorter as the spacer plate isn't needed? thanks.
Hilgie
Correct!
brianthemagical
thanks very much.
for future referance/search use, try other modle forums. after having no luck in the wanted section of this forum, i bought one within 24hrs on the gti-6 forum.
thanks, again.
