phil05 0 Posted July 11, 2007 Just wondering if a set of 15inch compomotive alloys from a "F" reg mark 2 golf gti would fit on a 205 GTI, if so would they need spaces Cheers Share this post Link to post Share on other sites
Anthony 1,003 Posted July 11, 2007 Nope - PCD is different (4 x 100 and 4 x 108 IIRC) so they won't fit I'm afraid. Ford fitment wheels will fit with spacers though, and Compo's seem to be fairly commonly available second hand in Ford fitment Share this post Link to post Share on other sites
sonofsam 5 Posted July 11, 2007 No they wont fit, different PCD, you can fit Ford wheels to peugeot ( wich will need spacers ) and that's about it without major hub mods see for yourself http://www.carlsalter.com/wheel_fitments.html My compomotive MO's will be up for sale soon wich have the right PCD and offset. Share this post Link to post Share on other sites
phil05 0 Posted July 11, 2007 Cheers you two was just an idea, on that website it says about the the "bore" what does it mean just for the future Cheers Share this post Link to post Share on other sites
sonofsam 5 Posted July 11, 2007 (edited) Bore is a great big f**kin pig Only joking, it's an engineering term for a hole and it's size so to relate that to wheels it's the hole(bore) in the back of the wheel that locates onto the hub/stub axle. Edited July 11, 2007 by sonofsam Share this post Link to post Share on other sites
welshpug 1,666 Posted July 11, 2007 thats bOAr not bore sam peugeot use 65.1mm, Ford uses 63.4mm you can get adapters to go from pug to ford, and there are even bolt on adapters to go from 108 to 100mm so you can use renault wheels etc. Share this post Link to post Share on other sites
Baz 421 Posted July 12, 2007 Lots of aftermarket wheels use a large std sized centre bore then use spigot rings to fit inside this to shim down to the required size too. Share this post Link to post Share on other sites
