trogboy 17 Posted July 10, 2007 There is a drain hole on the top of the sill behind the rear quarter panel - does it feed into the sill below the rear quarter? If you're not sure which one I mean it is just below the rear seatbelt winder mechanisms. Logic would say that it is supposed to take condensation that forms in the inside of the panel. The reason I ask is that I have just split the best part of half a pint of water into it but it hasn't come out of the drain hole in the bottom of the sill. I can't feed a piece of wire between the two holes even though they are only about 4" apart. Can someone please tell me that I haven't just drained water into an otherwise sealed section of the chassis? Share this post Link to post Share on other sites
Jrod 7 Posted July 10, 2007 (edited) If you look under the car next to the fuel tank there is a little rubber bung, try poking that. Edited July 10, 2007 by Jrod Share this post Link to post Share on other sites
trogboy 17 Posted July 10, 2007 I am very familiar with that bung as I have to poke it/take it out every time it rains as my sill on the passenger side fills up. That is where I was expecting the water to appear from but none was forthcoming. Share this post Link to post Share on other sites
Jrod 7 Posted July 10, 2007 Try parking the car so it drains that way? I'm sure they join up. Share this post Link to post Share on other sites
trogboy 17 Posted July 10, 2007 I tried to thread a long cable tie through and then a bit of wire but I couldn't even get close. Even with my finger deep inside the bottom drain hole I couldn't feel the wire moving about (this is starting to sound very wrong ) I was parked up with the backend facing down hill in the first place! I might go a try a couple of pints of water! It's got to start coming out of somewhere. Share this post Link to post Share on other sites
