markw
309 Lower Arms Again
markw
anybody know how much wider the track is on a 205 if you fit the 309 lower arms, also how much negative camber if any does it give.
All Praise The GTI
dont quote me but i think it is 1.5 degrees negative camber, makes alot of difference.
i have 309 front and rear setup!
Alastairh
good upgrade.
Tip: Make sure you have decent wishone bushes. New pug ones are about £30-£40, but 9 times out of 10, if the bushes are about gone, the ball joint is aswell.
And make sure you have your tracking 100% to see full benefit :unsure:
Alastair
kyepan
i did a post on track widths a while back, search it up.
more like £10-15 for the full set.
