Richie-Van-GTi
Cylinder Sensor?
Richie-Van-GTi
haynes shows a cylinder sensor connected to the bosch mp7.3 , is this the crank position sensor as it doesnt list that?
what car is that in?
Mikey S
knock sensor?
Richie-Van-GTi
no it lists the knock sensor seperate.From what I can tell the only engine sesnor not listed is the crank sensor but it does list a cylinder sensor.
Super Josh
Does it run sequential injection? If so, it could be the cam phase sensor, so that the management knows which cylinder is on its compression stroke.
Josh
Richie-Van-GTi
looking at the loom its a batch fire job and theres nowhere on the engine for a camshaft sensor to fit.
