Jrod
Does It Matter If Harness Touch The Cage?
Jrod
I wanted to put the second eye bolt where the red dot is but having a look underneath (and drilling the pilot hole :PB) ) there is no way you can get a plate under there for the eye bolt, at the moment I've put that one through the hole that held the boot matt but it just touches the cage.
Is it OK like this or should I have a re-think?
davepug205
should be fine you could always put a shoulder pad over
where it touches the cage to stop any rubbing
Jrod
I'm not to worried about it rubbing through just MOT etc...
picture seems to of stopped working so here it is again.
davepug205
aslong as its mounted properly using the eyebolt plates,
and the harness isnt frayed it shouldnt fail
