r.u.sure 0 Posted July 7, 2007 Can someone please tell me if there is an easy way to reconnect the adjuster arm from the headlight, back to the little ball on the end of the adjuster screw. I've had the light in and out so many times now I've lost count. Talk about awkard Any help would be greatly appreciated before this sends me mental Share this post Link to post Share on other sites
hengti 2 Posted July 7, 2007 bend a length of stiff wire in half, hook it round the plastic arm and use it to pull the socket back onto the ball Share this post Link to post Share on other sites
welshpug 1,682 Posted July 7, 2007 if you pop the inner side in first, then hook the thingy onto the ball with a finger, then put it into place by the indicator, seems to work best for me (you may find is makes it a lot easier if you remove the grille) Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 7, 2007 (edited) The way I do it is. *Plug in the headlight and sidelight *With the light hanging out get your fingers in around the adjuster and pull it sharply up onto the ball joint. *Clip the other side into its metal spring Job jobbed Edited July 7, 2007 by Edp Share this post Link to post Share on other sites
Paintguy 0 Posted July 7, 2007 I do it the same way as Ed. It's really easy to do whilst the headlight is still hanging out. Share this post Link to post Share on other sites
GLPoomobile 958 Posted July 7, 2007 Especially easy if you have spindly girly fingers like me Share this post Link to post Share on other sites
jim205GTI 3 Posted July 7, 2007 Mmm try telling my fingers that Hahaha i managed it somehow , after a light bout of swearing Share this post Link to post Share on other sites
r.u.sure 0 Posted July 10, 2007 (edited) Finally sorted both lights using a bit of wire as suggested by hengti did try the other ways, but that worked best for me. Obviously a bit of a wuss in the finger department you may find it makes it a lot easier if you remove the grille Forgot to do that in my hurry to get it done, Result: one superglued indicator Thanks very much for all the suggestions, appreciated lots. Edited July 10, 2007 by r.u.sure Share this post Link to post Share on other sites
