nunoserrano
Haltech Mi Base Map
nunoserrano
Hi could some one get me a Mi16v base Map for the Haltech E6X ecu ?? thanks
Yes, email me.
nunoserrano
Ok thanks i will
Here's the an E6X base map for the Mi16.
mi16_base_map.zip
cybernck
is this MAP or TPS based map? :blush:
MAP, with an external 1 Bar MAP sensor.
nunoserrano
Hi petert thanks for the map but once im using TB`s i should need a TPS map right ?
Try this one. It should get you running. I made it from the other one, so the mixtures might be a bit rough in places.
mi16_base_TPS.zip
cybernck
can someone send me Haltech software then? :D
or perhaps it's easier - a screenshot of fuel and ignition maps (the MAP ones) :blush:.
thanks.
And I thought you were an IT guru?
http://www.haltech.com.au/downloads.htm
Download E6X HalwinX Win, install, then open the first map I posted. You can see the maps in 2D, 3D or text values.
Edited by petert
cybernck
i've given it a quick look last night but couldn't see a download page anywhere.
cool, i can now recode it into MegaSquirt :(, assuming it will work fine with a DFW engine :D.
thanks!
karlo
Just curious, are these maps based on the stock Motronic maps or are they the result of RR mapping?
Five years of real life driving and dyno. You'll notice were I tried to richen the fuel maps, around 8ms. The reality was that the std. injectors maxed out. They could have been 10ms and it wouldn't get any richer.
karlo
Man, this is a great contribution to the mi16 community! Are these for a bone stock D6C? How well do you feel that the ignition map is tuned?
We've got two 205 mi16s running on Megasquirt already, and the lack of a proper ignition map is the only drawback at the moment.
Bog stock D6C. You could possibly improve the light load ignition mapping with more time on the dyno.
karlo
Marvellous! We may be able to do some RR tuning of this map later on, I'll post back with the modifications if we do.
