paul_portsmouth
Front Lower Strut Brace
paul_portsmouth
has anyone got a pic of a front lowere strut brace fitted?
TEKNOPUG
Why? If you need to know how to fit it, simply unbolt the forward wishbone nut on either side, place strut-brace over the bolt and then re-attach the nuts.
Jrod
paul_portsmouth
looked through the threads and found this post ( unanswered ) as mine did the same thing when fitted hence me thinking id put it in the wrong place. is it something to do with a worn engine mount?
QUOTE
Just fitted my Brace (lower) And there is a difference! BUT..........
It knocks on the sump when i accelerate, not the end of the world just get a harder mount.
when cornering i have a funny rubbing noise, as if the tyre is rubbing on the arch. Any ideas??? Took off the front wishbone bolt, put the brace on and did it all up, cant see i could have moved anything, really annoyin, only when pushing thru tight corners or roundabouts tho!
HELLLP hehe
SOrry to hijack, but it could be useful to some one!
QUOTE
also the sump was sat so low it was almost impossible to get a socket into the brace.
any ideas??
paul_portsmouth
Before
After
Edited by paul_portsmouth
Rippthrough
Aha, strut brace pimping thread! *runs to photobucket* :)
paul_portsmouth
thats a completely different shape
indeed, its one that Phillip makes himself as Its quite well known that OMP ones dont fit that well, and dont fit some applications at all, even though they are listed to fit...
come on phillip, when's the first batch of 205 ones coming?
pacey205
Because its on a TU I assume.
Rippthrough
When I borrow M@tt or Henry's car for a couple of hours after summer :rolleyes:
Anulfo
Obviously some mods are just non effective gimmicks but i've heard the front lower strut brace is well worth doing and very effective if done right.Any guys tried it and noticed handling differences with/without it?
Rippthrough
Quite a big difference imo, I took it off once to clean it up for some photo's, went off for a drive, I got off the estate, turned around, and refitted it before going back out!
Edited by Rippthrough
