Richie-Van-GTi 74 2 Cars Posted July 4, 2007 Just wondering how much should the cams overlap? Finally got mine setup to the point it all turns over fine etc, Ive got the inlet advanced to give 2.5 lift at TDC and the exhaust is also advanced as much as possible on the standard verniers to minimise overlap. Is it better to have less? Share this post Link to post Share on other sites
welshpug 1,666 Posted July 4, 2007 I dont know the actual specifics for thsi engine but it depends if you're after mid range grunt or top end power, as the cam timing can affect this quite a bit. Share this post Link to post Share on other sites
