bales 1 Posted July 2, 2007 As title, does anyone know what the spark plug gaps should be on the xu10 turbo engine, cheers. Alex Share this post Link to post Share on other sites
DamirGTI 344 Posted July 3, 2007 Hello ! This is from the "Autodata" for Citroen XM 2.0 CT ( XU10J2TE ) : NGK BCPR6ET , gap : 1.0mm Eyuem RFC58LS2E , gap : 0.8mm Beru 14FR-7LDU , gap : 0.8mm Bosch FR6LDC , gap : 0.6mm Champion RC8DMC , gap : ?? Hope this helps cheers Damir Share this post Link to post Share on other sites
welshpug 1,666 Posted July 3, 2007 If you get the right plugs for your engine they will allready be set to that gap. Share this post Link to post Share on other sites
craig f90 0 Posted July 9, 2007 (edited) If you get the right plugs for your engine they will allready be set to that gap. It's as welshpug says, even from my own experiences they are set to the cars required gap off the shelf. all that need is to decide which plugs suit your cars state of tune. Edited July 9, 2007 by craig f90 Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted July 10, 2007 (edited) It's as welshpug says, even from my own experiences they are set to the cars required gap off the shelf. all that need is to decide which plugs suit your cars state of tune. not necessarily true.... iirc ngk have 14 plugs that cover about 90% of the vehicle parc so not all engines have the same plug gap. its worth checking every time. Edited July 10, 2007 by pugger Share this post Link to post Share on other sites
