r.u.sure 0 Posted June 30, 2007 I've recently had a Gti-6 conversion done using the original Gti-6 manifold and can remember reading somewhere on the forum, can't remember where though, that some people advise using a heat shield to stop the bulkhead from getting to hot. As I'm not in a position to attempt making one myself, and would assume that I would need measurements etc if I went to a private company, I was wondering if anybody on the forum would be in the position to make one up for me and roughly what sort of price it would be posted or collected depending on distance. Sorry !! Wasn't sure where to post this, hope it's right. Thanks in advance Dave Share this post Link to post Share on other sites
Edp 67 3 Cars Posted June 30, 2007 You could probably use some king of heatproof material. Like this http://www.amber-performance.co.uk/shop.php?i=2401 Share this post Link to post Share on other sites
whizzer71 0 Posted July 1, 2007 I wrapped mine with exhaust wrap before I fitted it,Works really well and havnt noticed the bulkhead getting hot,hasnt singed or discoloured the paint so I guess it must be ok. Used heat reflective tubing on the coolant hoses and wiring harness also ! Tristan Share this post Link to post Share on other sites
r.u.sure 0 Posted July 7, 2007 The reason I was thinking more along the lines of a metal plate or similar is because of the limited access to the manifold. Thanks for the help anyway. Share this post Link to post Share on other sites
welshpug 1,723 Posted July 7, 2007 you coud use the heat shield off the 306 the engine came out of. Share this post Link to post Share on other sites
r.u.sure 0 Posted July 10, 2007 you coud use the heat shield off the 306 the engine came out of. I did'nt actually source the engine myself. Looks like I'll have to have a look around and see if there's any being broken then. Thanks for the help anyway. Share this post Link to post Share on other sites
Guest DanielVTS Posted July 11, 2007 I'm wrapping the Xsara manifold so I can get rid of the cheap and nasty fibre/foil heat shield that is fitted as standard... cat replacement pipe also wrapped so will help gas exit speed and therefore small power gains Share this post Link to post Share on other sites
