richosabroard 0 Posted June 29, 2007 i need to know if the clutchs on a 1991 205 1.9 8v are the same as a 1991 405 1.9 8v.As i need a clutch and the 405 was sold in North America and the 205's were not and it may save me haveing to ship one here if there are the same. Share this post Link to post Share on other sites
Richie-Van-GTi 71 2 Cars Posted June 29, 2007 (edited) just ask the supplier if it is a 200mm push type clutch, if it is then yes it will fit fine. If it isnt then it may be best long term to fit the 405 flywheel if its a size difference or a 405 clutch arm set up if its a pull type. I would gues that they will be same though. Edited June 29, 2007 by Richie-Van-GTi Share this post Link to post Share on other sites
brianthemagical 1 Posted June 29, 2007 just fit an mi16. Share this post Link to post Share on other sites
stux 0 Posted June 30, 2007 8v clutches are probably the same just do like Richie-Van-GTi says. mi16 is a 215mm clutch so If you want to fit it you must do it with mi16 flywheel. Share this post Link to post Share on other sites
richosabroard 0 Posted June 30, 2007 (edited) Thanks for the info.i have ordered a clutch for a 405 8v so when it arrives i will check the size if not then i will have to order one from the u.k Edited June 30, 2007 by richosabroard Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted July 2, 2007 As long as its for the same gearbox type (Be1 or Be3) the 8v clutches are the same. Graham. Share this post Link to post Share on other sites
