Doof 11 Posted June 27, 2007 Ok i've recently taken a lot of the engine ancilliaries off to clean things up in the hope of sorting my godawful idle out but since putting it all back together it seems to be pinking loads, if indeed the sound i'm hearing is pinking. Even at 3000 rpm with half throttle it seems to pink a little bit. The only thing that has changed that could affect it is the vacuum advance which i've reattached and the idle screw which might be out slightly too much. I'm gonna get thw WD40 out and check for air leaks, but what else could it be? Could the vac advance or slightly too open throttle screw cause it? Cheers, Lewis Share this post Link to post Share on other sites
welshpug 1,666 Posted June 27, 2007 the ignition advanve may/will need re-setting if you've re-attached the advance Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted June 27, 2007 try retarding the ignition slightly, this will allow you to close the idle screw as well. Share this post Link to post Share on other sites
