Nick C 0 Posted June 26, 2007 Does anyone have a guide on how to disassemble and reassemble the rear brake calipers as i need to change the seals. Cheers Nick Share this post Link to post Share on other sites
welshpug 1,677 Posted June 26, 2007 pretty easy really nick, wind out the piston with a screwdriver/wind back tool. using a scalpel or pointy scraper remove the seal and dust boot, clean thoroughly, lube new seal with brake fluid and re-assemble, winding the piston al the way back. when re-fitting slacken off the handbrake cables, pump the foot brake to set the pistons and adjust the handbrake accordingly Share this post Link to post Share on other sites
