Nick C
Rear Caliper
Nick C
Does anyone have a guide on how to disassemble and reassemble the rear brake calipers as i need to change the seals.
Nick
pretty easy really nick, wind out the piston with a screwdriver/wind back tool.
using a scalpel or pointy scraper remove the seal and dust boot, clean thoroughly, lube new seal with brake fluid and re-assemble, winding the piston al the way back.
when re-fitting slacken off the handbrake cables, pump the foot brake to set the pistons and adjust the handbrake accordingly :)
