DanS1982
406 Master Cylinder - 4601e1
DanS1982
Can anyone confirm this is the correct part number for the 406 MC that can be used on a 205 GTI and retian the original resovoir?
It is a 4 pot Non- ABS item with a 23mm piston, but is the holes correct for the 205 resovoir?
Cheers,
Dan
B1ack_Mi16
Cheers,
Dan
I can confirm that partnumber: 4601G1 is a 23.8mm M/C from early 406's without ABS.
MC is made of aluminium and has 4 outlets.
Piccy:
http://projects.205gtidrivers.com/b1ack_mi16-brakes/CIMG1038
DanS1982
Piccy:
And which resovoir did you use?
Anyone confirm the difference between the two please?
B1ack_Mi16
I did use a 205 GTI reservoir, and also of course 205 gti brake servo.
Hilgert said the 306 fluid reservoir also will fit.
No idea about differences, but I know that the partnumber I gave you is working perfectly. :blink:
DanS1982
No idea about differences, but I know that the partnumber I gave you is working perfectly. :)
Thanks very much!
