Guest labrat
Tyre Size
Guest labrat
OK, we're refurbing a set of 1.9 speedlines and they're coming up pretty well. So we've decided to put new rubber on them (F1's) so the question now is what size :
185 55 or 195 50
What do people suggest ?
And how much should we expect to pay ?
Where from ?
This will be on a standard suspension setup if that makes any great difference.
TIA
Guest ScoobyJawa
195 50 - much cheaper.
Eagle F1 GSD3 - 40-50 quid depending where from
Toyo Proxes T1-S - 30-40 quid depending
Guest Olly H
I agree, 195 50's are the way to go.
Mine had 195 45's on when I bought it, when I came to replace the front two tyres I found it cost hardly any more to replace all 4 with 195 50's, so that's what I did.
I got 4 pirreli 6000's for about £200.
However I'm not overly impressed with them, they don't seem to have as much grip as I'd like.
You can get them cheap online and get them fitted at a local place, but I don't know how much they would charge if they did it.
I just phoned up all the local tyre centres to find the best price.
Guest d-9
Silly question... do they have the same rolling radius?
Guest Olly H
almost.
185 and 195 are the width of the tyre in mm's.
the profile (50 and 55) is the size of the tyre wall as a percentage of the width.
185/55 has a tyre wall of 0.55 * 185 = 101.75mm
195/50 has a tyre wall of 0.50 * 195 = 97.5mm
So that's less than a centimetre smaller diameter for the 195's, not worth worrying about.
There's a good site on the net for calculating wheel and tyre sizes, but I forget where it is.
C_W
If you went from 195/45s to 195/50s is should have been a lot CHEAPER as they are a much more common tyre.
Think F1s 195/45s are around £60 compared with £40 for the 195/50s
Guest Olly H
It WAS a lot cheaper, was about £50 a tyre for the 50's and at least £75 for the 45's, your prices look like online prices, I just went to a garage.
Not a fantastic deal but I did shop around a bit, my mum recently paid £170 for two F1's (195/45's) on her polo gti !
Guest labrat
WOW !!! ... thanks for all the replies.
Hmmm, been phoning round a bit and noticed the 185's being quite a bit more expensive at about £90 with the 195's coming in at £60 ... as people have suggested the 195 50 is a much more common size.
Any suggestions as to the best place to get them from ?
Guest Brick-IT
The online tyre size calculator is great for checking how much the speedo will be out by and can be found at this page
Cheers,
Jim
