Guest DAZ_S16
Poping Out Of Gear
Guest DAZ_S16
hi i picked up a 205 mi16 yesterday,and for most of the journey home it kept poping out of 5th,and also sometimes crunching into 3rd and 4th,would this mean a new gear box or clutch?or something else?
thanks
Richie-Van-GTi
Id start with new linkages and check the balljoint bolted onto the subframe is tight. If it still does it then you need a new gearbox.
Guest DAZ_S16
it has new gear selector rods that should not come off which the guy got from miles,dunno if that would have anything to do with it???
hengti
had this before; checked the linkages over and was then advised that it was the selector forks (i *think*) - new box was required
KaspaCti
Worth checking the oil in your gearbox. My CTi kept jumping out of 5th all the time when I first got it. When I drained the oil from the gearbox all that came out was about 200ml :) As soon as I refilled it to the correct level it was fine.
Check the engine mount's, The adjustment of the gear-rod's and clutch but if it crunches in 3&4 the spring clip has broken inside the box
Guest DAZ_S16
ok thanks will check them.been speaking to paul and when ive done the starter motor im gonna pop down to your place miles.:D
pugpete1108
i got this on my proton compact :lol: gearbox at the mo, it jumps out of reverse when you apply any type of revs , i have just resigned myself to the fact that i will have to get greasy and wet and get under and change the box ^_^
