pugbliss 0 Posted June 26, 2007 Hi there. Can someone be very nice and tell me what i need to ask for exactly when im ordering this part??? ive gone into gsf and pug dealer to ask things before only to be told its called somethihng else all together after i had to describe what and where things are. i need a new ecu temp sensor (mounted on the S.A.D.) the car is a 1.6 gti 1990. ive done a search and the part number ive found is B93490 on the gsf website. Is it the same thing i want from a pug dealer? also does anyone know the price from a dealer? cheers Share this post Link to post Share on other sites
Revla 2 Posted June 26, 2007 Hi there. Can someone be very nice and tell me what i need to ask for exactly when im ordering this part??? ive gone into gsf and pug dealer to ask things before only to be told its called somethihng else all together after i had to describe what and where things are. i need a new ecu temp sensor (mounted on the S.A.D.) the car is a 1.6 gti 1990. ive done a search and the part number ive found is B93490 on the gsf website. Is it the same thing i want from a pug dealer? also does anyone know the price from a dealer? cheers Hello, Its not actually on the SAD, thats the black one for the SAD. The water temp sensor is the blue one on a water block (description?!) under the dizzy, near the SAD. Its only a tenner from GSF, about £8 at my local Camberly's. Not sure how much pug would charge- I bought one before from Emerald at about £10 too. So Pug will probably be around £18 I'd imagine. Someone has a link to an online parts catalogue on here, you can get the p/n# from that. HTH Trev Share this post Link to post Share on other sites
welshpug 1,666 Posted June 26, 2007 indeed peugeot want £18 for the ECU temp sender heres a pic and part number - 0280 130 026 (bosch part No) youll find the GSF and peugoet part numbers if you do a search Share this post Link to post Share on other sites
