brianthemagical
Flywheel Protection Plates On Xu 10's
brianthemagical
i was wondering what the xu10's used to protect the bottom of the flywheel in stead of the pice of metal on 205's? i've got an xu10 be3 box and the plate doesn't fit. is it per chance the sump? thanks.
pug309twin40s
im sure theres 2 different flywheel cover plates so might be you have the wrong one.
and if its a gti6 alloy sumped engine it wont have one either as the sump covers the end of the box.
Richie-Van-GTi
my sump covers the lot, its easy enough to modify your plate anyway, just trim down the sides and fold it back or cut it out.
brianthemagical
thanks for the replys. so would an alloy sump cure the problem? i want one anyway so it would save me some hassel. thanks agian.
I leave the cover off, helps the clutch bell housing drain any spillages easier.
brianthemagical
thanks for the reply, on the XU Engine & Gearbox Service and Maintenance page most of the current answers were by pugtorque.
the main reason i wanted it was because i have a lightened standard flywheel and i'm after a baffled sump. if i can't get a sutible sump i'll see about fitting the old plate and adding drain holes.
