M_R_205
Fitting A 306 Beam
M_R_205
i know this has been coverd before and iv done a search but i just wanted to double check, is it both the front and the rear mountings that are out or just the front ones, and by how much are they out??
cheers
Paul
I should think its both as they are in line with each other but I will pop out to the shed and check as I have both a 306 and a 309 axle in there, and a bare 205 tube :huh:
some measurements would be good so I'll take the tape out with me
right then, these arent 100% accurate to the MM but it gives people an idea of the dimensions.
rear bush bolt spacing.
306, in car (forgot to take into account the offset bushes, 306 tube off the car was totally bare!)
950mm
309 = 905mm (on the beam itself)
distance between rear bush stud and front mounting stud
306, 305mm and 295mm (306 uses offset mountings for passive rear steer)
309, 310mm
front mounting stud spacing is 60mm in both cases.
distance between front mounting inner studs,
306 = 905
309 = 825
one thing I noticed is that the crossmember brackets would fit either beam, though I didnt measure these in detail, but the spacing between these is 306 = 890mm 309 = 840mm, 205 800mm.
so it will fit under there but being 90mm wider it'd be rather too wide?
M_R_205
thanks alot for the measurements incredibly useful :D
i could easily make an ofset solid mount to for the back of the beam as its only a few mm i need to gain, the problem would be the front mount with the two studs, i could probably get my mate keith to weld up and ofset mount again to fit in the standard holes,
so on the front mount i need to gain 40mm each side or so
and on the rear mount i need to gain 22.5mm on each side
can you do me another huge favour? send me a pic of the front and rear mounts of the 306 beam, or are they exactly the same as the 205 ones?
think il go by myself a 306 beam, cant be that hard to fit :huh:
Edited by M_R_205
can do, it'll be Monday afternoon now though as I'm away for the weekend from tomorrow morning.
the rear mount is basically identical in construction, but the outer stud on the front mounting is 10mm further towards the front of the car than the inner one.
the only problem is that you have to use the 306's front mountings as the 205 ones fit to the tube whereas the 306 ones fit on the same bolts are the brackets.
M_R_205
thanks that will be great, theres a guy selling a beam near me im goign to see about buying it over the weekend, if i get my hands on it ther obviously there wont be any need for the pics :wacko:
Butler
Saw a pic of a 205 with 306 beam and the wheel stuck out hugely. Definitely need to chop the standard arches and fit some extensions to cover them, or a dimma rear. It would never pass an MOT otherwise.
sonofsam
or a Maxi kit!
M_R_205
im getting the extra mwide arches off ebay foor the front and the back :( shoul look well angry when im done, just need to think of a way to get the front track nice and wide without adding too much camber.. :S
