Bally 4 Posted June 20, 2007 (edited) WHich cams do you suggest. I have pulled down my Mi16 turbo to really set it up since it was my NA engine that I had just stick the turbo onto. Right now I have in the Kent PT1601 cams. should I reuse the std cams or stick with the Kent cams or a combination of the two? Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC Required Parts Sports Injection 1500-6000 10.06 10.06 262 Deg 21/61 61/21 I 110 Deg E 110 Deg 0.00 I 1.47mm E 1.27mm CF55 Edited June 20, 2007 by Bally Share this post Link to post Share on other sites
petert 607 Posted June 20, 2007 110 deg. is too narrow. Use the standard cams and #2 pulleys. Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted June 21, 2007 110 deg. is too narrow. Use the standard cams and #2 pulleys. both pullys number 2`s? i am also going to be doing an mi16 turbo soon and will save me a bomb on cams and verniers lol Share this post Link to post Share on other sites
