aitchy
Leaky Roof/sunroof
aitchy
I have noticed a leak overnight while it was raing i presume from the sunroof, although i cannot see the leak around the seals of the sunroof, the water is coming into the car via the interior light which is filling up and leaking?
anyone else had the same problem? what was the problem?
as said no leaks or water found around interior sunroof seals
steve@cornwall
Sounds like the rubber gone hard at the base of the ariel. If metal is sound replace the base, or just silicone around it ^_^
aitchy
sorted with some sealent round aerial base B) thanks
richiew205
yeh mine is doing the same, keep meaning to sort it out lol
