309PUG 2 1 Cars Posted June 19, 2007 Hi, After a car has been on the rollers mapping your DTA etc, would there be any performance to be gained by running 3bar fuel pressure instead of 2bar ?? I think the answer may be yes, but how much more bhp / lbs could be gained ??? 5% or 10% or is it more like 1% Chris Share this post Link to post Share on other sites
Craigb 2 Posted June 19, 2007 Surely you would also need additional air to accompany the fuel see a gain? the only benefit could possibly better atomisation . apart from a situation where the injectors had been maxed out and the engine running too lean? Share this post Link to post Share on other sites
petert 607 Posted June 19, 2007 (edited) Convert into psi, then divide by the square root: 3bar = 43.5psi 2 bar = 29psi 43.5^0.5/29^0.5= 6.6/5.4 = 1.22 or 22% richer Edited June 19, 2007 by petert Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 20, 2007 Convert into psi, then divide by the square root: 3bar = 43.5psi 2 bar = 29psi 43.5^0.5/29^0.5= 6.6/5.4 = 1.22 or 22% richer So if it could run 22% richer so to speak, if the engine was re mapped at the new fuel pressure of 3bar, what performance gain could be yielded ??? Chris Share this post Link to post Share on other sites
petert 607 Posted June 20, 2007 I'm not sure why you'd run at 2 Bar anyway. That means under vacuum, you could be as low as 1.2 - 1.5 Bar, which is very poor for atomization. Remember that the pressure is relative to the manifold vacuum. I'd much prefer to do the mapping at 3 Bar. Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 20, 2007 I'm not sure why you'd run at 2 Bar anyway. That means under vacuum, you could be as low as 1.2 - 1.5 Bar, which is very poor for atomization. Remember that the pressure is relative to the manifold vacuum. I'd much prefer to do the mapping at 3 Bar. I couldn't agree more about mapping at 3bar, unfortunately my mapping was done at about 2.2bar, we only noticed it after the event, we all forgot to check it at the time. So back to my original question, would I gain any more performane by getting it remapped at 3bar or is it not worth while ??? Chris Share this post Link to post Share on other sites
d-9 0 Posted June 21, 2007 (edited) You'll get an extra 34bhp. Would've thought it depends on wether ur injectiors are maxing at 2.2bar, if so then you could get more power but otherwise I'd have thought it wouldnt make that much of a differnce Edited June 21, 2007 by d-9 Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 21, 2007 D 9 Where the heck do you get 34 hp from ??? although the thought is nice. My injectors are not maxed out at 2.2bar. Okay it's 15 all so far, one says yes one says no, anyone else care to add there opinion. Chris Share this post Link to post Share on other sites
boombang 2 Posted June 21, 2007 (edited) Of course it wouldn't gain power unless it was running lean, you would just make the engine run richer and lose power. Possible damage: foulling of plugs (causing missing) bore wash (piston ring wear) oil contamination (reduced lubrication throughout whole of engine) If however you upped fuel pressure and remapped to suit, you may gain from better atomisation, giving better burn, better low running and pickup etc. Edited June 21, 2007 by boombang Share this post Link to post Share on other sites
deadcatdave 0 Posted June 22, 2007 Of course it wouldn't gain power unless it was running lean, you would just make the engine run richer and lose power. Absolutely, isn't it obvious this would happen? It's always a good idea to have an adjustable regulator and gauge before you get your mapping done. Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 22, 2007 Of course it wouldn't gain power unless it was running lean, you would just make the engine run richer and lose power. Possible damage: foulling of plugs (causing missing) bore wash (piston ring wear) oil contamination (reduced lubrication throughout whole of engine) If however you upped fuel pressure and remapped to suit, you may gain from better atomisation, giving better burn, better low running and pickup etc. So is that a yes ?? better performance if re mapped at 3bar ??? Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 22, 2007 Absolutely, isn't it obvious this would happen? It's always a good idea to have an adjustable regulator and gauge before you get your mapping done. I do have an adjustable FPR and a means to measure the pressure, we simply overlooked the matter until days later. Chris Share this post Link to post Share on other sites
deadcatdave 0 Posted June 22, 2007 So is that a yes ?? better performance if re mapped at 3bar ??? it's only a yes IF it was running lean. On the basis you've just had it remapped the the mapper undoubtedly used an AFR meter, it's very unlikely you'll see any difference. Does your graph show the AFR on it ? Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 23, 2007 it's only a yes IF it was running lean. On the basis you've just had it remapped the the mapper undoubtedly used an AFR meter, it's very unlikely you'll see any difference. Does your graph show the AFR on it ? Hi, The graph does not show the AFR but I do know it is running ever so slightly rich if anything. If in that case my engine at 2.2bar is NOT running lean why bother running 3bar fuel pressure ? Chris Share this post Link to post Share on other sites
boombang 2 Posted June 23, 2007 Better atomisation of fuel would be one - kinder on the engine and should help pickup at lower engine speeds. Basically should help to give a more complete burn as fuel How much difference it makes is a different matter, but tbh I can't think of any injection cars that run fuel pressure as low as 2bar. Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted June 24, 2007 Better atomisation of fuel would be one - kinder on the engine and should help pickup at lower engine speeds. Basically should help to give a more complete burn as fuel How much difference it makes is a different matter, but tbh I can't think of any injection cars that run fuel pressure as low as 2bar. Okay then, do I really need to remap the engine if I upped the fuel pressure to 3bar ??? Chris Share this post Link to post Share on other sites
Sandy 191 Posted June 24, 2007 Yes, please don't screw about with it, without a proper handle on what it's doing to the air fuel ratio. Share this post Link to post Share on other sites
deadcatdave 0 Posted June 24, 2007 chris, have you considered running a wideband display ? very handy for a track/race car. Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted June 24, 2007 like this one ? here Share this post Link to post Share on other sites
