Jrod 7 Posted June 15, 2007 Right I've taken off my shocks but on the offside bottom bolt the bush has come apart leaving the metal bit firmly attached to the bolt. I managed to grip it to try and turn it which is how I got one off before but this time the whole bolt just turns and because of the design you cant get a spanner or socket on the end. I also tried beating it to try and hit the bolt through the bush but it will not shift (even with a f*** off sledge hammer!) Don't really want to cut it off so wondered if anyone has any ideas? Share this post Link to post Share on other sites
Richie-Van-GTi 72 2 Cars Posted June 15, 2007 could try heating it up before bashing. Share this post Link to post Share on other sites
chris1986 1 Posted June 15, 2007 if i read that right ut sounds like you only need a new bolt they're only a couple of quid would save you a lot of hassle Share this post Link to post Share on other sites
Jrod 7 Posted June 15, 2007 Yes I probably will need a new bolt but I can't get the old one out as the metal from the shock bush has seized onto it! Want to try and get it off without cutting though. Share this post Link to post Share on other sites
Veero 1 Posted June 15, 2007 Soak it in PlusGas and try the hammer again. Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted June 15, 2007 vice or press?? Share this post Link to post Share on other sites
Jrod 7 Posted June 15, 2007 I tried a vice! Unbolted it off my worktop rather than take beam apart but it was just a tiny bit to small! Share this post Link to post Share on other sites
trogboy 17 Posted June 15, 2007 Have you tried heat? If you have then I'd have to go with angle grinder - Sorry man. Share this post Link to post Share on other sites
Rupertfinch 6 Posted June 16, 2007 (edited) Had the same issue while removing Spax to replace with oil filled pug shocks. Spent an age leaning on it with mole-grip pliers, bugger all happened! Only option in the end was to use a blow torch, a couple of good whacks and a hammer chisel combination. Oh and make sure to use a shed-load of plusgas or WD40 (as plusgas was on it's last legs by the time the OSR sleeve was removed). Edited June 16, 2007 by Rupertfinch Share this post Link to post Share on other sites
jonnie205 1 Posted June 16, 2007 I have had a few of these that are very very hard to remove. It will be arm off and somehow mount it in a press and see if it will come out with lots of heat. If it wont come out with a few hits of the sledge hammer ime afraid it will be arm off. Once i had now luck getting one out and had to fit a new arm Share this post Link to post Share on other sites
Jrod 7 Posted June 16, 2007 I can just cut it out and have no intention of removing the arm. Will try some heat/gas if not its angle grinder time! Share this post Link to post Share on other sites
Jrod 7 Posted July 9, 2007 f*** youuuuuuuuuuuuuuuuuu bolt. http://img401.imageshack.us/img401/6978/photo0015gk9.jpg Has anyone got a spare? It's the offside if it makes a difference? edit=pugtorque; imge file size. 120k max please. Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted July 12, 2007 Has anyone got a spare? It's the offside if it makes a difference? I've got a spare lower bolt, I'll put it in with your stud conversion when I send them down. Both sides are the same though. Graham. Share this post Link to post Share on other sites
