clifton
Harness Points
clifton
:unsure: after a long search and just got even more confused....i want to know where people have mounted there 4 point harnesses.....the only one im 100% sure on is im goin to put 2 eye bolts behind the handbrake!
pictures of where each point is mounted to would help alot :rolleyes:
also how many eye bolts and plates should i order for mounting 2 harnesses?
cheers
ben
One behind the handbrake for inners, use the existing belt rail bolt holes for the outers, and the rear seat belt mounting holes for the rears should give a reasonably good angle mounting point, if not a bit further back on the boot floor.
Edited by BazGTMi
cheers
ben
for the method above, i'd order 5 eyes and plates, and 2 eye bolts for the outers. :rolleyes:
Edited by BazGTMi
chris1986
i have a post somewhere on here with lots of pics with all the mounting points on for 4 point
