webby997
Starting Problems
webby997
I'm having problems with my 1.6gti (j reg).The problem is it doesnt start,it might start now and then but will not start all the time.It will though easily start when bump started.I've wiggled connections etc and the battery is only a few weeks old.Any help/advice would be much apprecaited.Thanks
Mikey G
Could be a bad earth, check the aerth connections on the gearbox and body near the battery. While your cranking the engine a bad earth could be taking all the power away from the ignition circuit which is why it will start on a bump.
steve@cornwall
have you tried to bump start? this may point to ignition amp if it will fire from a bump start
Just read this reply (By205007) in another thread
http://forum.205gtidrivers.com/index.php?s...76430&st=10
Hope it helps
ashlee205gti
Spade connector on starter motor? Usually down to the brown multiplug.
brianthemagical
does it turn over?
webby997
Thank you for all the replys.It seems to have been solved after taking off and putting back the dizzy cap.-cheers
