Trick 1 Posted June 13, 2007 I plan on adjusting the beam at the weekend, after reading the guide on main site, it recommends using a 19mm head bolt to get the plate off... anybody got a spare one i can have please? or what else can i use..? Share this post Link to post Share on other sites
Alastairh 47 Posted June 13, 2007 Just use a rear caliper bolt Share this post Link to post Share on other sites
dani959 0 Posted June 13, 2007 Just use a rear caliper bolt Yep, absolutely spot on! If you feel VERY lucky (like I did and it worked ) you can try using an old head bolt. Bear in mind that it increases the risk of damaging the threads on the plate. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 13, 2007 If you feel VERY lucky (like I did and it worked ) you can try using an old head bolt. Bear in mind that it increases the risk of damaging the threads on the plate.The thread of a headbolt is totally different to the thread you need for the ARB end plate so a Bendix caliper mounting bolts is the best option. You can usually find them on the floor around any 205/s or other Pugs in scrapyards easily enough. Graham. Share this post Link to post Share on other sites
Trick 1 Posted June 13, 2007 im sure ive got some spare caliper bolts from when i bought the brake fitting kit from pug years ago...i`ll route around the garage.. Share this post Link to post Share on other sites
welshpug 1,675 Posted June 19, 2007 any M12 x 1.5 threaded bolt will suffice, I.E a ford wheel bolt etc. there'd be plenty of these in the scrap yard (17mm) Share this post Link to post Share on other sites
