Anton green
Engine Goosed?
kyepan
Yep, big end bearings. Replacing them this week.
how hard was this to do, and did you regrind the crank?
j
M@tt
big ends are pretty easy to do just a case of drainig oil, removing sump and then changing bearings a piston at a time as you'll have to rotate the crank to get to them all.
It would depend on the condition of the surfaces as to whether you want to do a regrind (and measuring with a micrometer to check that they are still within tollerance), if you do want a regrind then its alot bigger job. Gearbox off etc
Edited by M@tt
